I installed Readcache SSD a few days ago w/o any problem. ExpressCache is enable but the its status window indicates 29,82 GB for the total cache size and only 0,07 GB for the used portion cache. When looking at the cache monitor windows, there is near 2.000 MBytes read.
Why the used portion cache never increases even when I execute several applications doing a lot of read I/Os ?
Configuration : Windows 7 profesional and 2 disks in software RAID 1.
your link is the same as the first. can you post screens hots of the disk managment window? how exactly do you ahve your RAID set up and where is the RC SSD in relation to the RAID.
Can you please provide a system configuration description? Do you have a RAID configuration? Can you see the cache read/write activity from the command line prompt “ECCmd -info” ?
I am assuming that ExpressCache/ReadyCache is installed on the C: Drive. Can you eliminate the D: drive from the configuration, reinstall ExpressCache and recheck the usage via " ECCmd - info" at the command prompt.
I inverted SATA connection between DVD and SSD. No change :
c:\Windows\System32>eccmd -info
ExpressCache Command Version 1.0.94.0
Copyright® 2010-2012 Condusiv Technologies.
Date Time: 11/17/2012 10:59:45:754 (PAT #8)
EC Cache Info
Mounted : Yes
Partition Size : 29.82 GB
Reserved Size : 3.00 MB
Volume Size : 29.82 GB
Total Used Size : 76.25 MB
Total Free Space : 29.74 GB
Used Data Size : 0 Bytes
Used Data Size on Disk : 67.75 MB
Tiered Cache Stats
Memory in use : 0 Bytes
Blocks in use : 0
Read Percent : 0.00%
Cache Stats
Cache Volume Drive Number : 0
Total Read Count : 17067
Total Read Size : 290.71 MB
Total Cache Read Count : 0
Total Cache Read Size : 0 Bytes
Total Write Count : 30170
Total Write Size : 211.27 MB
Total Cache Write Count : 0
Total Cache Write Size : 0 Bytes
I installed it on my second computer and it works fine. Boot time went from 3:46 to 1:44 on an old sata I mobo with Athlon 3700+ 2gb ram I guess I will try another brand for my main system.
