I just bought a ReadyCache and installed it into my Windows 8 machine. The software (1.2.1) says it’s “caching…” but never loads anything into the cache - stuck at 0.07 Gb. I then tried installing it into my other PC - Windows 7, and it has the same results:
ExpressCache Command Version 1.0.100.1
Copyright⌐ 2010-2012 Condusiv Technologies.
Date Time: 10/3/2013 20:29:28:511 (XANADU #2)
EC Cache Info
Mounted : Yes
Partition Size : 29.82 GB
Reserved Size : 3.00 MB
Volume Size : 29.82 GB
Total Used Size : 76.50 MB
Total Free Space : 29.74 GB
Used Data Size : 0 Bytes
Used Data Size on Disk : 68.00 MB
Tiered Cache Stats
Memory in use : 0 Bytes
Blocks in use : 0
Read Percent : 0.00%
Cache Stats
Cache Volume Drive Number : 2
Total Read Count : 118196
Total Read Size : 3.10 GB
Total Cache Read Count : 0
Total Cache Read Size : 0 Bytes
Total Write Count : 81902
Total Write Size : 1.41 GB
Total Cache Write Count : 0
Total Cache Write Size : 0 Bytes
Cache Read Percent : 0.00%
Cache Write Percent : 0.00%
With the first PC, I ran a bunch of programs repeatedly over several hours and reboots, and nothing ever cached.
Any idea what’s going on?
