I have an e260 that started giving me a black screen that said " Load main image failed Switch to Recovery mode"
I came here and found what should have been a solution to that problem that had me updating the firmware. I followed the steps and downloaded the firmware updater then I put it in recovery mode and tried to update the firmware. However the sansa updater is displaying my e260 as a e250 and is saying that there is no Update service availible. So is there actually a problem or is it Pebkac (Problem exists between keyboard and chair).
I don’t know if the firmware updater works in recovery mode. You probably need to do a manual update (download the firmware bin and extract it to the recovery partition). Note, doing anything but copying a firmware file in recovery mode will brick your player!
There’s no difference in the firmware between the e250 & e260. The only difference in these 2 players is the memory size.
However, you need to manually install the firmware. Don’t install the Updater. Here’s a post explaining how. Don’t follow the link in that post to the firmware though; it’s broken. Instead, the latest e200 series v1 firmware can be found here.
Ok I am definetly blond. I am also not fluent in geeky computer speak (although I wish I was) I downloaded the file e200v101.02.24a. I then copied it to the 16MB-Format. Then I did a safely remove hardware and it said on the mp3 player something like " Safe to remove Firmware Update complete"
then i unplugged and it did a restart. When I turned it back on it still had the “Load main image failed Switch to recovery mode”
So my next questions are
a. Can I screw this up any more that I already have?
I downloaded the new firmware,I connected the sansa express player to pc and it was read as drive letter,then it asked me to format it ,then I formatted,when I started the “sansaexpressupdater”,it didnot work.it displayed the window “donot disconned your player” but no progress,I see the player turned to flash drive,what can I do now??? help me please
