and the problem im having is the micro can not locate the licnese on vista and windows 7 to let me in my locked files but works on xp and xp pro has anyone had this problem and how can i fix??? Thanks for any info…
When you run it run it on one of the Win XP systems. You might also want to backup your documents and the U3 hidden system folder before doing the install. It never hurts to be safe.
