Cruzerlock not installing
Can’t find the reply in the email so I’m posting here instead.
  • The exact model of your device
  • Color of your device.
  • Capacity of the device.
  • Part number of the device (Take note of all the number on the device).
  • Date of purchase. (MM/DD/YYYY)
  • Where are you located? (Country, City, Physical Address and ZIP code)
Cruzer USB2.0 Flash Drive
Black, with white sliding tab
4GB
SDCZ36-004G BH1007VPKB
06 OCT 2010
Singapore. 260001
Windows 7 Ultimate 32-bit
AMD Athlon 7750 Dual-Core
2GB RAM
Yes I’ve tried installing Cruzerlock using a laptop running Windows Vista
Downloaded the file from http://www.sandisk.co.uk/Retail/Default.aspx?CatID=1274
No I’ve never used/installed U3.
Case ID number for this incident is: 501610
1: Cruzer is detected and funtional
2: Cruzer is not in the drop downlist
  1. My specs
  2. Yes its a goddamn Cruzer
Jamesyclone:“Windows 7 Ultimate 32-bit”
" I’ve tried installing Cruzerlock using a laptop running Windows Vista"
CruzerLock™ 2:"
Supported Operating Systems
  • Microsoft Windows 98se
  • Microsoft Windows ME
  • Microsoft Windows 2000
  • Microsoft Windows XP Home
  • Microsoft Windows XP Pro "
Come now… XP is what, 10 years old? Would it be too much to expect a piece of software that is compatible with the current trend? =\
Encryptx:" Attention San Disk Customers:
CruzerLock is not compatible with Windows Vista. Receive 25% off when purchasing SecurFlash, our Vista-compatible product. SecurFlash works on ANY flash drive and removable Hard Drives."
http://www.encryptx.com/eCommerce/productinfo.php?lic=RMA8QPLAQ73XGR3S4AGAPUK94C)"=&rstn=sand001
sandisk is no longer affiliated with encryptex so you would need to purchase the software from them.
