Good news!
I have the Audible Manager sorted out. The new Manager client has many features in addition to the Windows Media Player compatibility. If using Windows Media Player, _the device must first be authorized using the Audible Manager. _If a file is transferred without doing this, it will be unreadable by the device, but it will be visible in the Audiobooks node, including album art.
If you have transferred a book using Windows Media Player and it does not play, or you notice that the total time displays in the order of hundreds of minutes, fear not! Plug in your device and open Windows Media Player, then click on the Sync tab. Find the book by “album” title on the device and delete using Windows Media Player. If you get a popup asking “delete from library, or from the computer”, you are in the wrong place. Click on the Clip Zip at the left of the ecreen, selecting Internal Memory > Music > Albums > book title. Unplug the device and let it refresh its music database first.
Open the Audible Manager, and download the SanDisk Digital Players plugin. If it shows as already installed, go ahead and let the client download the plugin again, and close the Manager client.
Open the Audible Manager once again, and plug in your Clip Zip. Give the client a moment to list the device as Clip Zip. At the left of the screen, right click on the Clip Zip, and select Activate. Now, select your desired book at the top of the screen from your library, and then click on Add To Device.
Alternately, if you prefer to use Windows Media Player to manage your books, you can also do this now that the device is authorized. The new Audible Manager will send a reference to your books in the Playlists node at the upper left of Windows Media Player’s main screen. You can also transfer from there.
There will be a new feature added to Windows Media Player if you try playing a book title while in WiMP. A small window will pop up during playback with the Chapter Skip feature. Even if you minimize the WiMP screen to the small view, this popup will automatically follow you along. If you like, clicking on the Audible logo will open a browser to the Audible web page.
Bob :smileyvery-happy:
