YES YOU CAN HAVE PLAYLIST FROM BOTH SP AND SD MEMORY
FOR ALL YOU PEOPLE HAVING TROUBLE SYNCING PLAYLISTS - AND ESPECIALLY THOSE WITH SD MEMORY CHIPS INSTALLED.
Re: Can you make Playlists and synch them on micro sd?  —  YES!
Dammm I just spent 20 minutes writing this up and the smiley thing wiped it out - went to a new page - backed up and a blank screen — arghhhh…
well - this will be shorter and you can figure out the program yourselves - it really is easy - I just was bragging on the program some.
I wasted three 14 hour days messing around with all the major programs - would not put a playlist on the Sansa.
Then I found this beautiful gem.
go here - http://hcware.110mb.com/sansa/  – click the enlarge link - for a great image.
Simple program - no more syncing.  work in SMC mode and see both drives - copy from your Import file directly to your SD or SP memory.  Makes playlists that use BOTH memories at the same time. Songs in both memories in the same playlist.  Program is free but I will be making a donation.  Much easier to use in MSC mode.  Note Sansa Beta note at bottom of page.  If you sort your files first (do track then album) and they will be in playlist in same order if you take full albums as I do.
It works IN the Sansa - no syncing!  Playlists are exactly what you make them.  First time creating database takes a few minutes - I have over 600 songs in 3.5G of memory.  Note the blue and yellow squares at left - tells you what memory your songs are in. And the memory usage at bottom.  A very rare and well done program (sorry no pun intended).
from his home page -
Create Edit And Arrange The Playlist On Your Sansa e200 Series Mp3 Player In The MSC Mode
Yo! Tired of Windows Media Player in MTP Mode but you still need a playlist.  Maybe you just prefer using the drag 'n drop method of putting stuff on the Sansa Then here's your solution. Use your Sansa e200 in MSC Mode and have playlists.
Message Edited by davestea on 09-30-2007 08:48 AM
Message Edited by davestea on 09-30-2007 08:50 AM
