Directions for updating Clip Zip Firmware says
"Extract the clpza.bin file from the .zip file you just downloaded into a folder on your computer.
• Once extracted, drag the file to the root directory of your Sansa Clip Zip"
In layman’s language please, exactly where do I find that “root directory” ?
Sorry, but the two answers received don’t fit my non-nerd understanding of “layman’s language”
I would like to know where I take that unzipped file to
I mean is there a folder somewhere I put it in or ??
It would be the drive folder that is assigned when you plug the player in to your computer with a USB cable.
So for example mine is showing as SANSA CLIPZ F: as a drive in Windows explorer. Click on that and you’re the ‘root directory’ or folder. So the root directory is F: Sorry, but it doesn’t get any more basic than that,
Slow down, I only have a bachelor’s degree in Engineering
I plugged in my player and under “Portable Devices” I see “Sansa Clip Zip 4GB”. When I click on that I see “Internal Memory”
Are you saying I should now take my unzipped “Upgrade Firmware” file and shovel it into “Internal Memory” ?
Sorry to be so dense on this subject but
I attached player to computer
I opened Windows Explorer
I see Libraries: “Documents”, “Music”, “Pictures” and “Videos”
I don’t see Clip Drive
Please help me get over this “hump” so I can learn something here
I’m using Windows 7
I just don’t see what you think I should see
“Open a Windows File Explorer window” doesn’t register with me
When I click on accessories I see “Windows Explorer”
When I click on that I see “Documents” ---- no View option at top
To answer your previous question, if you can find your way back to that screen that shows “Internal Memory” then, yes that is where to drag that clipza.bin file.
This is mentioned on the page that describes how to manually install the firmware upgrades on your Clip Zip:
http://forums.sandisk.com/t5/Sansa-Clip-Zip/Sansa-Clip-Zip-Firmware-01-01-21/td-p/297767
You could also follow the instructions on that page about turning on MSC mode on your Clip Zip. This effectively turns the player into a standard USB device which will be easier to navigate in Windows explorer, and have a drive lettter assigned, but otherwise functions as before. You’ll need to unplug the clip zip before this operation, and plug it back in afterwards,
I dragged my unzipped new firmware file to Internal Memory and then removed player from computer.
Player did not indicate that any sort of download followed.
Was I supposed to remove the firmware already on the player?
I already had the latest firmware on my player, but “Sansa Support” insisted I should re-install that firmware.
All of this has to do with my inability to download NPR radio files to my Clip Zip Player.
“Sansa Support” plans to send me a replacement player. I’m not sure that is the solution.
