I have the battery status indicator on my Clip, but I see numerous posts telling about one on the computer.
I’ve connected both MTP and MSC and can’t find it. MTP mode doesn’t allow me to show properties, unless I go to Device Manager and then no battery charge indicator. MSC allows me to show properties, but still no battery charge indicator. I have firmware 20, Win XP Home and WMP 10 on 2 PCs with same results.
Also, several posts have indicated that you can’t charge the Clip with it turned off. Mine charges both ways, but if it is turned off when I connect it to the PC, it looses my position on the playlist and next time I use it, it comes on with the menu showing. That’s a bummer and should be fixed in next revision of the firmware.
