I really like the earbuds that came with my clip. They’re the best-sounding I’ve ever tried that are that shape (all the better-sounding high end ones have that huge rubber earplug design which I find really uncomfortable).
But I wasn’t as careful with them as I should be and they shorted out (bent the wire too many times).
I’d really like to get a replacement set. Does SanDisk sell those earbuds separately? (I couldn’t find them on the SanDisk website.) Or is there anywhere else you can buy them? Are they manufactured by SanDisk, or could I get equivalent ones from whoever makes them for SanDisk?
You could go to Bestbuy or wherever and look at a few different kinds.
There’s a JVC set that looks pretty much like them for about $10. And return if you don’t like them??
Well, I’ve tried a lot of those, and never found any even remotely as good as the ones that came with my clip, so I’d rather not just randomly buy ones that look the same and hope they sound good.
Watch ebay or buy.com for cheap Sansas, throw them away, keep the earbuds. ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/apple/slight_smile.png?v=12)
The earbuds w/ the e200 series are the same. ![:wink: :wink:](https://emoji.discourse-cdn.com/apple/wink.png?v=12)
I have a new pair that I’ll send to you for the cost of S&H. Send me a private message.
