Hi! Under Settings - System Settings there is a category called “Volume” and the choices are either “Normal” or “High”.
However, changing it seems to have no effect on anything.
What is this for, and what does it do?
Thank you!
Thank you!
It simply limits your maximum volume. if you put it on normal . You should put it on high and forget about it forever afterwards. ![]()
