Hey,
I noticed the function in the menu ‘settings’ to set the volume to normal or high. Its setting was at normal. But when I changed it to high, nothing changed.
I wonder why this function is created?
Paul
Hey,
Paul
@paul8924 wrote:
Hey,
Paul
It doesn’t automatically make it louder…it gives you the option to make it louder. Try this. With it on normal, set the volume at 50%, then switch it to high…the volume should now be lower, by 4-5 clicks. It’s not a huge difference, but it’s there.
