I’ve bought a SanDisk Estreme II SSD 2 days ago.
I plugged it to the first SATA port of my motherboard, and a SATA power cable. Then I started my computer and installed Windows 7 Pro without any issue on the SSD, but after I shutdown the PC, the SSD isn’t detected anymore in the bios.
The thing is that if I enter bios setup, SSD isn’t detected the first time, but from here if I restart the computer it is going to be detected on the next launch.
Identically, from windows, if I do a “reboot”, everything works fine, but if I do a shutdown, then SSD won’t be detected the next time I start the computer.
Do you think I should return back the SSD?
Thanks in advance
