Hi. I’m very happy using my Clip for running and have been using it a while. However, the actual clip on the back of the Clip player has now broken - with the spring having broken through the plastic. As it is removable, it would be trivial to fit a new one… but how can I get one?
thanks very much!
SanDisk used to sell them, but since the original clip has been discontinued for a few years now, they no longer do.
People have posted various alternatives, both here and at the anythingbutipod.com Clips forum.
It will never be a same feel with the old one. I think you could use this as a good excuse to buy a new one. Perfect for a new year. ![](https://global.discourse-cdn.com/sandisk/original/2X/8/89e303e1bebd7a98eec72f7c287baa259557cee9.gif)
