Damaged Clip (not the unit, the attachment on the back)
How can I go about getting another clip for the rear of the unit?
I’ve had it almost a year now, love the device, but after daily use at work, the clip simply exploded and the pin and spring are no longer.
Tried to search, but searching for “clip” on this site is definitely a joke. :slight_smile:
As far as I know, you can’t. For a while they were available for sale, but I don’t think that they are anymore. A shame, since so many people broke them.
anything else that works for another product to slide in the back?   I can’t see this thing lasting being thrown around, set down, stuffed in my pocket.
I’ve got the same problem.
If you’re in the US you can order one from here:
I’m in the UK, so am looking for a supplier locally, as they won’t ship overseas.
Nice find! They used to only sell them in 3-packs, and they were out of stock for  along time.
sweet!   awesome.
I ordered 2. just in case.      the second one was only another .45 cents on shipping… like a 2nd clip is going to cost any more to ship than a single one…
thanks again.
I’ll update when I get it, to make sure all is good.
Well, that’s new! Those definitely weren’t there last time I checked. Maybe SanDisk is still upgrading and tweaking their website.
Well, i’ve got good news, and i’ve got better news.
The Good:  It’s the right clip for the Clip.
Better news:  When you buy them, they’re selling them in 3 packs!  I ordered 2… and got 6!
Clip clip problem solved!!!
Thanks, that’s very good to know!  The clip on one of my Clips is starting to crack, too.  Three should be enough!
yep.  Just a fair warning… it ships in a box big enough for a large phonebook, but alas, could fit inside a ring box.
you mean
Clip clip
Clip clip
Clip clip
Clip clip
Clip clip
Clip clip
problems solved! :smileyvery-happy:
Out of curiosity, where does it say they’re a 3 pack?  It seems to be one clip for $4.99 according to the website.  Did you find it out when you got your shipment that 1clip order means 3 actual units?
hi tnmats,
It does not say anywhere that it is a 3 pack, so I ordered 2.  Just got the box today and I got 2 - 3 packs (6 clips total). And yes it is $4.99/3 pack.
@jas32 wrote:
hi tnmats,
Cool.  Thanks for the info.
BTW, if you see the clip starting to crack, try what I did: drop a dab of epoxy glue on the crack on front and back of the clip.  I saw a crack forming at the spring but it was about 1-2mm long.  I dabbed some epoxy glue I had and after a few months it seems to have arrested the crack.  Likely the blop of glue acted as both a stress reliever and reinforced the plastic in the area.
