I have a newer laptop, less than 1 year old. After spending ALL DAY trying to get my Sansa clip to work and I have discovered that I think I do not have USB 2.0.
Should it work anyway? Is there any chance that is my problem?
It could be but I think it should not create any problem. Try formatting your device using the Format option under the Settings and see if this will fix it.
Make sure you have WMP11 on your computer as well.
Thank you. I will try both of those things.
