hi,
I think this is nothing new but I still can’t find a solution.
When I open up my vault I get the following message “Invalid archive” then “this vault could not be loaded, it may be located on another computer or the original vault file has been manually removed”
All files are there in the expected folder “SanDiskSecureAccess Vault”
Tried to copy it to another key regenerate the vault “going trough the wizard at start” then changing the idx, idx.bak files for the one from the original key then renaming them with the name of the newly generated idx files.
Same result. So it seem that the IDX files are the issue. Anyone know how to regenerate these files? Is there a repair utility some tools, command line?
I even have a backup of the vault but it just bring back the same issue.
I would really like to get my stuff back.
Please help me out.
Steph.
