Hi!, thanks for your reply!. I tried using a different usb cable and port as well. When I try to use another computer it always tells me that there’s no internet connection and I’ve already tried in 3 different computers running XP but different service packs. Nothing seems to work!. I will post the whole log thanks a lot!
===== Begin execution =====
06 Aug 2009 14:11:36,968 INFO - Executing process C:\Program Files\SanDisk\Sansa Connect Device Recovery.\cmdline\zsi_fw.exe -r 32…
06 Aug 2009 14:11:37,328 INFO - ZSI FW load starting.
06 Aug 2009 14:11:37,328 INFO - Open USB Device start
06 Aug 2009 14:11:37,328 INFO - found a device!
06 Aug 2009 14:11:37,328 INFO - Attempting to open \?\usb#vid_0781&pid_7481#5&2ad2f960&0&3#{184954e0-9128-11db-b606-0800200c9a66}
06 Aug 2009 14:11:37,328 INFO - opened device!
06 Aug 2009 14:11:37,328 INFO - completeDeviceName = (\?\usb#vid_0781&pid_7481#5&2ad2f960&0&3#{184954e0-9128-11db-b606-0800200c9a66})
06 Aug 2009 14:11:37,328 INFO - Opened successfully.
06 Aug 2009 14:11:37,328 INFO - data completeDeviceName = (\?\usb#vid_0781&pid_7481#5&2ad2f960&0&3#{184954e0-9128-11db-b606-0800200c9a66}\PIPE01)
06 Aug 2009 14:11:37,328 INFO - ID: 003507040d2cce41a8b5fb9e0300a48d
06 Aug 2009 14:11:37,343 INFO - Device ID=[003507040d2cce41a8b5fb9e0300a48d]
06 Aug 2009 14:12:01,468 INFO - Requesting images from [https://SC01-P032.zing.net/UserPortal/Updates/Recovery.aspx?\_zinfo=d%3D003507040d2cce41a8b5fb9e0300a48d%2Czkf%3D0.0.0.1%2Cv%3D2]
06 Aug 2009 14:12:06,875 ERROR - Exception when trying to get firmware images: System.Net.WebException: The remote server returned an error: (304) Not Modified.
at System.Net.HttpWebRequest.GetResponse()
at ZSIServices.ZRequest.GetResponse()
at ZING.DeviceRecovery.Managers.DeviceRecoveryManager.RequestFirmwareImagesFromService(ZUserAgent userAgent, ZDeviceInfo deviceInfo, ZAccess access)
06 Aug 2009 14:12:06,953 INFO - Calling sw update tool with => [“C:\Program Files\SanDisk\Sansa Connect Device Recovery.\cmdline\zsi_fw.exe” -w “C:\Program Files\SanDisk\Sansa Connect Device Recovery\RecoveryImages\003507040d2cce41a8b5fb9e0300a48d\everest_vmlinux_ext_prod_1.1.1.50239.srr.e” “C:\Program Files\SanDisk\Sansa Connect Device Recovery\RecoveryImages\003507040d2cce41a8b5fb9e0300a48d\everest_initrd_ext_prod_1.1.1.50239.srr.e”]
06 Aug 2009 14:12:06,968 INFO - sw update tool output – start:
06 Aug 2009 14:12:07,031 INFO - ZSI FW load starting.
06 Aug 2009 14:12:07,078 INFO - Found encrypted file: everest_vmlinux_ext_prod_1.1.1.50239.srr.e
06 Aug 2009 14:12:07,125 INFO - Found encrypted file: everest_initrd_ext_prod_1.1.1.50239.srr.e
06 Aug 2009 14:12:07,125 INFO - Open USB Device start
06 Aug 2009 14:12:07,140 INFO - found a device!
06 Aug 2009 14:12:07,140 INFO - Attempting to open \?\usb#vid_0781&pid_7481#5&2ad2f960&0&3#{184954e0-9128-11db-b606-0800200c9a66}
06 Aug 2009 14:12:07,140 INFO - opened device!
06 Aug 2009 14:12:07,140 INFO - completeDeviceName = (\?\usb#vid_0781&pid_7481#5&2ad2f960&0&3#{184954e0-9128-11db-b606-0800200c9a66})
06 Aug 2009 14:12:07,140 INFO - Opened successfully.
06 Aug 2009 14:12:07,140 INFO - data completeDeviceName = (\?\usb#vid_0781&pid_7481#5&2ad2f960&0&3#{184954e0-9128-11db-b606-0800200c9a66}\PIPE00)
06 Aug 2009 14:12:07,171 INFO - Loading: 1008000 16809984 1754944
06 Aug 2009 14:12:08,734 INFO - Done!
06 Aug 2009 14:12:08,734 INFO - Loading: 4400020 4294967295 1783808
06 Aug 2009 14:12:10,312 INFO - Done!
06 Aug 2009 14:12:10,375 INFO -
06 Aug 2009 14:12:10,375 INFO - sw update tool returned with exit code [0]
06 Aug 2009 14:12:10,375 INFO - sw update tool output – end
06 Aug 2009 14:12:10,406 INFO - CopyZAPImageToDevice => [“C:\Program Files\SanDisk\Sansa Connect Device Recovery.\cmdline\zaprecover.exe” -t 600000 -f “C:\Program Files\SanDisk\Sansa Connect Device Recovery\RecoveryImages\003507040d2cce41a8b5fb9e0300a48d\yeverest_zap_ota_rel_1.1.2.65799.tar.gz.e” “C:\Program Files\SanDisk\Sansa Connect Device Recovery\RecoveryImages\003507040d2cce41a8b5fb9e0300a48d\yeverest_zap_ota_rel_ext_prod_1.1.2.65799.sig”]
06 Aug 2009 14:12:10,640 INFO - ZAP Recover output start:
06 Aug 2009 14:12:10,671 INFO - ZSI FW load starting.
06 Aug 2009 14:12:10,734 INFO - Found encrypted file: yeverest_zap_ota_rel_1.1.2.65799.tar.gz.e
06 Aug 2009 14:12:10,734 INFO - Found unencrypted file: C:\Program Files\SanDisk\Sansa Connect Device Recovery\RecoveryImages\003507040d2cce41a8b5fb9e0300a48d\yeverest_zap_ota_rel_ext_prod_1.1.2.65799.sig
06 Aug 2009 14:14:00,750 INFO - found a device!
06 Aug 2009 14:14:00,750 INFO - Attempting to open \?\usb#vid_0781&pid_7482#5&2ad2f960&0&3#{088db354-111f-11db-9804-b622a1ef5492}
06 Aug 2009 14:14:00,750 INFO - opened device!
06 Aug 2009 14:14:00,750 INFO - completeDeviceName = (\?\usb#vid_0781&pid_7482#5&2ad2f960&0&3#{088db354-111f-11db-9804-b622a1ef5492}\PIPE01)
06 Aug 2009 14:14:00,750 INFO - completeDeviceName = (\?\usb#vid_0781&pid_7482#5&2ad2f960&0&3#{088db354-111f-11db-9804-b622a1ef5492}\PIPE00)
06 Aug 2009 14:14:00,750 INFO - Can’t write connect packet!
06 Aug 2009 14:14:00,750 INFO - Error waiting for device ACK!
06 Aug 2009 14:14:00,750 INFO - ZAP Recover output end.
06 Aug 2009 14:14:00,750 ERROR - Unexpected error occurred while recovering the device.
ZING.DeviceRecovery.Managers.CouldNotRecoverDeviceException: zaprecover tool failed to copy ZAP image to the device. Exit code [-1]
at ZING.DeviceRecovery.Managers.DeviceRecoveryManager.RecoverDeviceInternal(Object notUsed)
===== End execution =====
