Sansa Fuze/Rhapsody question
Hey everyone I wanted to ask a question about the rhapsody software and the Sansa Fuze. I purchased my Fuze in 2009 and used the accompanying Rhapsody software to load all my music and videos at the time. Where the problem comes in is now, two years later, I no longer have the software and want to change things which I had before. Except I can’t even see anything which I used Rhapsody to load… I have tried several times finding the correct download, with no success. I can access the normal drives through a normal PC interface but everything I used Rhapsody is invisible to me. Can anyone help me figure out how to see/modify these contents? Any help or advice would be awesome! Thanks a million
Settings/System Settings/USB Mode. Change it to MTP. Your computer needs to have Windows Media Player 10 or above installed. You could also reinstall Rhapsody software.
Rhapsody uses digital rights management garbage software to control what you can do with downloads. If your Rhapsody subscription has ended you may be able to find the files in WMP mode but not play them.
