~hello,
if i want to convert a movie i can only do it after a long time, or else it stays at zero procent
ive got a sansa fuze. 4 gb
~hello,
Afraid you’re going to have to give us more to go on. ![]()
I would suggest looking through some of the already existing gazillion or so posts regarding videos issues both here and on the Sansa Media Converter board. If nothing seems similar, or none of the existing suggestions work, then feel free to post again, but give us some details to work with.
Tapeworms correct, do a search for “movies” and you’ll find a ton.
For the Fuze SMC to work you’ll need to convert a movie on another program first. Lots of ideas on the various posts on which ones to use.
those two have good ideas but simply just convert the movie into AVI format it is as easy as that,not what they are thinking.
Hi -
I’ve owned this Fuze for about 36 Hrs and am incredibly frustrated - so much so I may return it! Can’t imagine going through so much ■■■■ just to listen to music and see a few videos and picts!
Read your msg about converting to AVI - you said “it is that simple.” Do you mean that once the videos are in AVI I can directly load them to the Fuze as is? Or is the conversion to AVI just a prep step to converting them with the Fuze software? I’m confused (even more…)
Pilgrim
Once it is in AVI you can then use the media converter to add it to the player.
@pilgrimspride wrote:
Hi -
Pilgrim
If the movies are in .avi you should be able to use the SMC to put them on the Fuze or a card.
If they are not in .avi format you will need toconvert them first using another program, then SMC.
Music is very simple with the Fuze. I just rip CD’s to Windows Media Player and then Sync to my fuze. If I purchase them from a site, then I download them, open My Computer to them and right click to Sync and it opens WMP and then I sync to my Fuze. There are other ways, but this is easy and simple for me.
Pics I had to use SMC too. But that was actually very easy and quick.
Like these two said yes you can
