hello man just buy a sansa microsd card and insert it into ur sansa express just click on ur device.it boots up from the card then go to settings and format internal memmory.once again telling internal memmorey coz external memmory have ur card datas.then remove the card and switch on your device
I am facing same problem. Few days before when I turned on Sansa Express MP3 player, startup logo appeared and then nothing happened. It was off. I tried hard reset as per User Guide but no luck.
Now, I tried Firmware update as well but the device itself is not detected.
i solved my problem a long time ago. I just got an email now and i saw u guys still posted here so…
If u have the same problem, look for toturials in this forum, write “Sansa express doesnt work” or something like that, u’ll find planty of threads explaining how to fix the device.
I dont really remember how i fixed mine, u need to put it in the usb while pressing the volume down button for like 10 seconds, untill the computer recognizes the device, then download a driver or something like that…
I tried every conceivable fix. Those on this site and many others. I buggered around for just about two days. Then I read a tip on some website - can’t remember where. It said I must insert a MicroSD card in the external memory card slot and switch on the Sansa. I have the 1 gig model.
I used my Nokia mobile phone memory card which had other stuff on. It worked first time !!! Sansa back from death and still working without any problems. Even after I removed the card. Unbelievable but true !!!
So simple, when you think about all the high tech solutions that everyboby suggests. I also did the latest firmware update without problems after the card trick.
I use the Sansa on my home theatre for music playback, still the greatest MP3 for that for me
Sandisk, where are you in all of this ??? Surely you should read all these posts and come up with advice ???
