I have an old Sansa e200 v1.0 and I have a few questions if anyone still remembers them.
When I plugit into Win7 X64 using MSC mode the unit just fails to connect. I receive and unknown device error that won’t go away without a reboot of the PC. The screen on the e200 says connected/disconected over and over so I’m assuming it’s a compatiblity issues with Win7? Windows 7 native transfer mode pops up when connected via MTP mode.
What is the larged microSD card the unit supports? I know the card doesn’t support microSDHC, shouldn’t it read a 2gb card at least? My 2gb card doesn’t show up as free space in settings or in WIndows 7 as MTP or MSC.
Anyone ever try the 3rd party app rockbox on it?
I know the unit is OLD OLD OLD in techno years but it still works and I hate to just toss it.
Thanks
- When I plugit into Win7 X64 using MSC mode the unit just fails to connect. I receive and unknown device error that won’t go away without a reboot of the PC. The screen on the e200 says connected/disconected over and over so I’m assuming it’s a compatiblity issues with Win7? Windows 7 native transfer mode pops up when connected via MTP mode.
Probably some weirdness with the USB drivers on your PC. I use the e200v1 with Windows 7 and have not had any issues in MSC mode. Since MTP mode still works, the USB port on the player can’t be broken.
smitty870 wrote:
2. What is the larged microSD card the unit supports? I know the card doesn’t support microSDHC, shouldn’t it read a 2gb card at least? My 2gb card doesn’t show up as free space in settings or in WIndows 7 as MTP or MSC.
2GB in the sandisk firmware, 32 GB in rockbox.
smitty870 wrote:
- Anyone ever try the 3rd party app rockbox on it?
I prefer it, but then again I wrote a bit of it
Thanks for the reply! I ended up loading an old disk image of windows xp mce onto my laptop and the unit worked fine.
Must be something with Windows 7 not liking my e200 which is weird.
I did like the rockbox nice job! I’m giving the mp3 player to my father and I decided the rockbox my bit a little bit much for him.
