When I bought it everything worked perfectly for about a month or so. But then, suddenly, the player wasn’t recognized anymore by Windows XP. I reinstalled Windows (for other reasons), updated to WMP 11, but nothing worked.
I also reformatted the player, then set it to hold mode, pushed the middle button and plugged it in- nothing happens. No “windows-device-plugged-in” sound, no message, nothing. The only thing that happens is that the Clip starts charging its battery.
So, what else do you think I can do (apart from sending it back?)
I have exactly the same problem! Because I sync my Sansa Clip with my laptop, I thought it was only a problem of my laptop. I reinstalled Windows XP, too. But it doesn’t matter. Then I tried to sync my clip with my normal pc, but nothing happened either.
