Sansa Clip "jumps" when playing Podcasts
my new Sansa Clip 8GB “jumps” very often, when I play longer podcasts. It skips some time (from seconds to minutes) and plays on. Sometimes it “jumps” back and plays from the beginning of the first jump… but then it goes on to the "broke location"and jump to the timeof the second jump. Because of my bad english I’ll try to say it with a example:
0:00 to 1:30 normal playing
1:30 jump to 2:00
2:00 to 3:00 normal playing
3:00 jump to 1:30
1:30 to 2:00 normal playing
2:00 jump to 3:00
3:00 to End (best case :wink: ) normal playing
Best Regards
Robbi
Try updating the firmware and also use the devices “Format Command”.
It will set the cluster size to 32K.
