Hi.
I have a sansa clip that my friend gave to me last week. Everything works on the unit. But there is one issue i havent solved until now. When i connect the unit to a PC using a USB cable, it automatically directs to the Menu without the “connecting” word appearing. The battery icon blinks which indicates that the unit is charging. But the player cant be detected by the PC, nothing really happens. My sansa clip charges but doesnt connect. I tried every possible solution that i have found on other sites. I have tried connecting it to other PCs and using different cables. I just cant make it connect.
Please help!..
Thanks
