I have sansa mp3 player of 2GB. I am unable to connect it to my pc.
whenever i connect it to my usb drive it is only charged and not detected please let mt knoe the problem.
thank you.
and also tell me how to format it
thank you.
Are you using the USB cable that came with the Clip? (If so, good)
Did you by any chance buy your Clip at Best Buy, and install the proprietary software disc that they ionclude with it? (If so…bad!)
I have the same problem., no pc that used to see the device can see it now. Device never displays connected message…plus I cannot put the clip in MSC mode (no settings/MSC mode option and Lock/center button does not work. Also, a reset holding the power switch does not indicate anything was reset. The clip will play what is on the device, it will charge fine.
This seem to happen after a full drain of the battery. after the next recharge, it stopped connecting when plugged in.
thank you for help.
i got to know how to format the sansa clip.
but the problem is that whenever i connect
it to my laptop which os is windows vista it
gets connected fast
but when i connect it to my pc it shows that
it is connected as the green icon appears in
task bar but it is not shown in my computer.
I am not using the cable i got with the sansa clip.
Plz help me out with this.
Do you use the same cable to connect the Clip to the PC and the laptop?
(Just trying to rule out the obvious- not all USB cables are the same…some have more connector pins inside…)
