My sansa clip 2gb is stuck on writing when connected to my PC and then won’t turn on when disconnected. Can someone help?!
If it’s one of the original Clips, it might be a broken solder joint connecting the battery wires inside. This was a common issue.
But in case it’s not that, have you tried resetting it?
Yes, I did
Try setting the Clip’s USB mode, under System Settings, to MSC mode, and see if that helps.
The Clip+ manual: http://mp3support.sandisk.com/downloads/um/clip±en-um.pdf
I can’t see where this is going to help. ![]()
