Sansa Clip 2 GB
I have a black and a pink 2 GB Sansa Clip. The black works fine but the pink does not turn on at all even when connected to USB port. Even if I press the on/off for few seconds, nothing happens. Anybody knows the fix?
Thanks.
Fully charged?
Did you try holding the power switch in the off position for 15 seconds in order to do the re-boot?
I think you mean the ON position. :smiley:
If that fails, it’s probably a dud. The OP should have it replaced.
ack i have a black Sansa Clip 2 GB and it got wet and now it wont turn on how do i fix it couse my mp4 got washed and it works perfect
