My 500 GB drive doesn’t show up on my MacBook anymore. This started last week. I thought it was the USB C cord. It is not. I have tried 6 cords. I have also tried connecting to my iMac. Nothing. I think the USB connection in the drive is broken. Can I take this drive apart and port the storage to a new container? I have at least a year or two worth of Ableton sessions that i need to get off of this device. I was told this device was next to indestructible and i DID NOT BACK IT UP. First rule of data … not followed ARG! HELP
Hi @wilsonSloane,
Have you opened a Support Case? If not opened, for more information, please contact the SD Technical Support team for the best assistance and troubleshooting:
A. The external hard drive does not on Desktop or Finder but is visible in Disk Utility
It usually means the drive is connected but not properly mounted or the Finder preferences are misconfigured. Steps to resolve this the issue::
Reset Finder Preferences – Ensure External disks is checked in Finder Preferences under General and Sidebar.
Manually Mount – In Disk Utility, select the drive and click Mount
B. Your Sandisk external drive is not showing in Disk Utility or anywhere
If your MacBook cannot detect the drive at all, it could be a connection, cable, or hardware issue. The following steps might help you:
Reconnect the Drive – Try different USB ports, avoid hubs.
Check Cable and Port – Swap USB cable or port.
Test on Another Computer – Verify if the drive itself works.
Also read: How to Find External Hard Drives on Mac (Even Not Showing Up)
