Hi,My sandisk Cruzer Force 32GB USB drive is recognized as hard drive, which shows up in the Hard Disk Drives section instead of Removable Storage section. I would like to know how to fix this. bcoz i wanna to create bootable USB driver.pls help .~
There is no fix, it is what it is. However that should not stop you from making it bootable. Seach here and on Google for RMPrepUSB. It’s a utility that can make the drive bootable.
But i still have something want to know, could u pls teach me how to define USB is recognized removable driver or hard drive when i buy usb next time .~
The hard drive concept is in support of Microsoft’s Windows 8 To Go concept. And while Sandisk was supporting that concept for a while it no longer is. What the difference is in the packaging of the Cruzers to indicate which is which I don’t know. Sorry.
SanDisk’s RMA may cover returns for this situation.
I was in the process of making my flash drive bootable, then I exited the command prompt abruptly. Now, my computer doesn’t recognize my flashdrive at all. How do I go about reversing that?
I apologize for the delay, in answer you, I hope, be of equal useful.
What happened, is that your message, is lost in another thread, on another subject, and I saw it casually, and caught my attention.
1- I assume, of course, that already revised drivers, and tested the UFD, in other PCs.
The simplest solution is to return it, you have a guarantee: http://www.sandisk.com/about-sandisk/contact-us/
2- Meanwhile, you can investigate, whether any of these portable utilities (free), can detect your UFD: - USB Flash Format (HP) 2.23 - USB Flash Repair (LLF) 2.91 - USB Flash Fbinst Tool 1.60 - USB Flash BootICE 1.32
For no lose more time, you can download (free) from here: http://filecloud.io/_cpweb34i
Luck, and then you tell us, what happened, please.
