i tryed to put music on the audible and it didn’t work
and i have an album mix up too. Also i don’t even have the time on the MP3 player its only on the system settings i need help maybe the next firmware update will help will it
Unknown/unlikely if there will will be a firmware update.
Help from SanDisk–phone support could be helpful:
im have a problem with the album mixup and the clock on the Sandisk Clip Sport mp3 player and the Audible folder under books i need help and a firmware update to fix it
Did you contact SanDisk as suggested above? That’s what SanDisk’s Technical Support is there for.
