Sandisk Clip Sport Go not showing all files
Sandisk Clip Sport Go.
Copied non copy protected Mp3 songs to the player.
They show up in File Explorer. When I search for them in the player, they are not there.
Any solution to this?
Hi @User6
(Get Support for Your SSDs and Flash Products | Sandisk)
(Contact Support | SanDisk)
Firstly, check the “Music” folder. Make sure your MP3 files are copied into the device’s Music folder (not a custom folder or the root directory). Next, check the ID3 tags. Because if the tags are missing or corrupted, the songs might not show.
Perform a firmware reset on the SanDisk Clip Sport Go and ensure audio files are located in the /MUSIC root directory.
