hi i have a problem: i wanted to delete rockbox and put on the OF , nur after i did so with the rockbox software and copied the OF to the root it does nothing, meaning after i reboot the player it says LOADING FIRMWARE FILE NOT FOUND next to the rockbox symbol
Are you holding the REW button to boot into the OF so it will complete the firmware update (and overwrite the version with RB in it) instead of trying to boot into Rockbox?
Try to old power for 30 seconds it should reboot itself.
But if you do not hold the REW button down as I said, it will try and boot into Rockbox and never complete the firmware installation. It must boot into the OF in order for the firmware to over-write the Rockbox modified one.
