Hi: I have a different problem. I do not know if the problem is my Sansa e260 or Rhapsody software. Before on Rhapsody it would load all of my songs into the software, now it loads only 60 songs on the computer, not all of them that are listed on my Sansa e260. I am stumped. Please advise. Ramjet 739
Use MTP mode (Found under settings>usb mode or mode). Check the files you are loading if they are supported by the Sansa e260 (mp3/wma). Error messages would also help if there are any.
Check the bottom bar of rhapsody if there is a yellow exclamation mark after the transfer process. Click on it and post the message.
