Hi!
Try to make this short…but probably not…these are the procedures I follow:
1. Sign in to Rhapsody
2. Connect my device
3. Create playlists in My Library
4. Create playlists on my E260
5. TRY and transfer playlists from My Library to my device using
the drag and drop method
6. Unhook device
7. Look at playlists on my device
8. Multiple songs of the same title, all songs for a certain playlist
do not show up under that playlist but are under All Songs
9. Hook device back up to Rhapsody
10. Try and drag and drop playlists from My Library to device
11. Unhook device
12. Same thing happens over and over…
13. Go to My Library in Rhapsody and my Playlists only have a
couple of songs I had downloaded from Rhapsody to Playlist,
have to re-format E-260 and reload all songs that are missing
from My Library that were previously there, and re-drag and
drop on my device.
14. Have to PURCHASE certain songs when I have a
membership with Rhapsody which were just on my Sansa 2
minutes ago
15. HELP…I just want to put songs on my E260 and have the
playlists be the same as when I loaded them and when I
hook back up to Rhapsody have My Library playlists have
ALL the songs in them that were there when I loaded
them…
Does it have to be in a certain mode for transfer and/or I have also re-formatted my Sansa many, many times…
I am ready to throw my Sansa through SanDisk’s WINDOW. I have had it only 5 months and it has been doing this since onset. Am I downloading songs wrong? Or should I be using Windows Media Player? HELP!
