greetings,
i’'ve reformatted my 2 gig sansa clip (settings->format ->yes) in an effort to regain the ability to add/delete songs to my sansa clip. unfortunately, rhapsody continues to load a few songs i have deleted! (34 of them, to be exact!) what’s worse – at song 21 of 34, rhapsody CHOKES and doesn’t go any further, which keeps me from being able to load any new songs onto this clip. sure, i liked these songs – but its time for a change. how do i delete these songs, loaded from my rhapsody subscription, and make them go away successfully?
thanks,
~sher
I would like to suggest to reauthorized your device from Rhapsody and format your device;
How to reauthorized the device;
- Connect your player to the computer using a Sansa cable.
- Choose Manage the device using Rhapsody on initial connection.
NOTE: This option is available only if the Rhapsody software has been installed on your PC.
- Right-click on your Sansa player from the Sources area.
- Select Authorize / Reauthorized
How to Format your device using computer please visit this link;
http://kb.sandisk.com/cgi-bin/sandisk\_en.cfg/php/enduser/std\_adp.php?p\_faqid=444&p\_created=1225240443&p\_sid=XKBJWWCj&p\_brand=&p\_accessibility=0&p\_redirect=&p\_lva=120&p\_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjY2LDI2NiZwX3Byb2RzPTAmcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWhvdyB0byBmb3JtYXQgc2Fuc2EgY2xpcA\*\*&p\_li=&p\_topview=1
Hope this would work.
