I am trying to format my drive back to it’s original condition, now it says My Extreme Pro says 1.3GB capacity and it is a 2TB help!
Plus I have to always put in the ‘unlocker’ password I have searched everywhere, on how to remove this! HELP… This shouldn’t be this hard?
              Hi @simonirl,
To resolve this issue we would request you to please format your product via SD formatter tool with help of PC.
Please download the SD formatter tool using the below link:
https://kb.sandisk.com/app/answers/detail/a_id/14827
Please be informed that if you forget the password then SanDisk does not have any method to bypass the password security feature on Secure Access software. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you forget the password there is no back door entry to unlock the drive. You can format the drive, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. Moreover, if you want to use Secure Access again then you need to first format your flash drive after taking back up of all your data which is in your flash drive.
Title: Please refer to below link to download Secure Access software:
Link: SanDisk SecureAccess 3.02 Support Information and Download
