while i’m trying to listen to my connect it hangs up and reboots…I’ve done a factory reset on it and I my current versions are:
ZAP: 1.1.1.50371r
OS: 1.1.1.50239
Boot loader: 24450
I would love to use the recovery tool but when I try to install it and it nears completion i get an error “DPInst result: [-2147483648]” I’m currently running Vista Ultimate 64bit.
any information you could provide would be helpful
Look for a file called DPINST.LOG … it should be in your Windows directory, probably C:\Windows. I don’t have an example of that log so I’m not sure how it’s formatted, but if it has date-time values in it, look for entries around the time that your recovery tool installation failed.
