Hello, I loaded some mp3 Bible study lessons from a series of CD’s I own. After I had finished listening I wanted to delete them and load the next set. They are showing up as read only and I cannot delete them. Any ideas on how I can remove the protection without having to reformat the player?
Try right clicking on the files, and look for Properties on the drop down menu. Now, look near the bottom of the Properties Window and there should be a checkbox/option for “Read Only” and “Hidden”. Try unchecking Read Only and see if you can delete them now.
Hi, i have the same problem with the read only files. I tried to change it but the option is blocked. I have Windows XP SP2 and i have administrator privileges. I also tried in another computer. What can I do?
Thanks
