Is it possible for me to transfer music onto the micro sd card by connecting my sansa connect to the computer with the card in it? Or do i have to buy the micro sd card adapter to transfer music to the card.
On my system (Win XP, Win Media Player V-11) when it recognizes the “Device” to synch to, there should be a small arrow under the Device name when the Micro SD Card is installed. Mine defaulted to the Micro SD card for download/synch destination, and the player’s “internal memory” had to be selected as an alternate destination.
Your mileage may vary… Hope it helps.
Thanks that was very helpfull.
You can connect your microSD card into your Sansa Connect and transfer content into your microSD.
