Hello i have a macintosh, i try to connect my “Sansa connect”, but it’s not Recognized by my apple, Neither I have Usb’s option SMC, There is some way of connecting it to my macintosh?.
Thanks & regards
Santiago
Thanks & regards
Santiago
The Sansa Connect requires the MTP protocol on the host computer, in order to copy media to its internal memory. Google “(mac OR macintosh) mtp” although I can’t tell you that any of the mentioned solutions will work with the Connect.
As an alternative, the Connect takes microSD/microSDHC cards, so you can copy songs onto one of those cards using your Mac, and then put the card into the Connect.
Message Edited by PromisedPlanet on 07-27-2009 02:06 PM
Ok, but if I do not have any memory microsd that I do?
Thanks!!
Santiago
Thanks!!
Santiago
I’m sorry, I don’t understand your question.
If you’re asking about microSD/microSDHC, it is a memory card that you buy:
