I got the Fuze 8GB and wanted to use it with Winamp. I have the newest version of it and the firmware on the Fuze.
When trying to copy flac files onto the fuze, it tells me that that format is not supported on the device. Manually copying it over via MSC is no problem and it can be played.
Where is the problem? I know the fuze got the flac upgrade with a later firmware, so did the devs forget to tell the device that it knows flac for MTP?
Another small thing you might be able to help me with. I manually copied files to the Fuze in the beginning, but when I now open it in Winamp it shows no artist or anything on the device. The player is correctly labeled in the portables section.
When clicking Sync, winamp crashes. This crash only happens when there are files on the device that aren’t in the media library so it would copy them into it.
