problem sansa clip
:cry: I have a clip sansa, Buy it two months ago, and did not delete it, when he was installing music,
which when you turn just stays in a screen that says sandisk, and try Recovery Device,
But does nothing. What else can I do
I’ve never seen any reference to a ā€œrecovery deviceā€ with the Clip.Ā  Are you sure you don’t have the Sansa Connect?
If you have the Clip:
  1. Connect it to your PC in MSC mode: slide the hold/power switch down, the while pressing the center button, plug your Clip into your PC’s USB port.
  2. In Windows Explorer, find the Clip, right-click on it, and select Format.
  3. In the ā€œFormat SANSA CLIPā€ dialog, check ā€œQuick Formatā€, then click on OK.
:cry: I did what I suggested and not step anything, the computer does not see the mp3.
The ā€œRecovery Modeā€ message sounds like you have a sansa e200 series player.Ā  Try here:
Hope this helps!
Bob
Message Edited by neutron_bob on 02-07-2008 07:31 PM
