Hello guys I got massive problem, my pc and my player says that I got 200 mb left, but when I go to the files in my pc all files appears empty so I can’t delete anything!
Its huge problem coz I want to change all the music in it, any ideas what I can do?
If you have a backup for files that might be on clip, format and start over restricing yourself to either MSC or MTP all the time. Unless you are using protected titles, stay with MSC
You should see everything when using the clip. Look in folder marked MTP under folder option and see what files are there.
