I keep doing that, nothing works, it seem to be just the screen that’s broken cuz when i hold the power button to turn it off, it turn off it about 4 seconds, the time that it akes for the Fuze to turn off. I can upload a video showing my problem.
It certainly could. The connection to the screen may have shorted out.
That screen sounds very dead, and unless you can live without a display it’s time to consider a new unit.
The Clip+ is inexpensive, takes the microSDHC card (make sure it’s a Clip Plus) and has comparable sound with the Fuze–all you lose is the video, which never worked so well anyway. Or splurge on a new Fuze.
ok i’ll try the white rice technique, i’ve done it before for my cell phone which actually did had water got into it. i’m not sure about this one though, it did happened after it rain, but it was in my pocket.
Is your Fuze a v1 or a v2? If the former, you can install Rockbox with the voice prompts and see if everything but the screen works. Tou might even be able to use it that way, although your enjoyment of videos may be somewhat limited. :robotwink:
If the LCD itself is the problem, you can probably get a broken Fuze with a good LCD for around $15. I’m about 95% sure that the Fuze LCD’s are fully interchangeable between models. If anybody can raise or lower that 95% figure, please do so. :wink:
The only difficult thing about replacing the LCD is reconnecting the face plate afterwards.
