Hi all,
I just got my Sansa clip, and I’ve tried to scan the forum for info on this & did some reading & downloaded mp3tag, but I’m pretty confused here, and would really appreciate a bit of help–
I downloaded playlists from Windows Media Player & they worked fine (file extensions of .mp3 and .wma). But, the volumes were at different levels, so I downloaded mp3gain and levelled the volumes of the songs, no problem. I wanted to clear the old playlists so there would be no confusion, went to "my computer>sansa clip>open>memory>playlists and deleted the old playlists.
Then I put all the volume levelled songs in a folder on my desktop, rebuilt the playlists in windows media player, they worked fine there, and then re synced them to the clip. The titles showed fine in playlists, but of 4 playlists consisting of 6 or more songs in each, only 2 songs were in 2 of the playlists, and the others had most songs but not all.
I tried reloading several times, no luck, and windows media player kept telling me that the clip had those files already. The missing files aren’t file protected, and played fine the first time.
I tried deleting all the music files out of the clip to clear it and start from scratch, but that’s when I have windows media player telling me it already synced those files.
I tried loading all the volume levelled files in the folder on my desktop into the clip as music & not playlists, and some showed up in the clip but not all. . .
If anyone can help me with this, I would be a happy gal!
Thanks.
*edited to say, I worked on the problem again today, and realized that while the song titles appear on the Clip, there is 0 memory there, and the Clip looks as though it’s playing a song, but there’s no sound.
Message Edited by homegardener on 08-18-2008 06:09 AM
