Thanks for the answer the first clip+ I got had a battery problem, after 5 days it just died! as this was the second MP3 exchange I ad to do, I was getting a “Bit” angry, I got my replacement clip+, put my SD card in and jumpe on the bus, At this point I nearly through it out the window as at full volume I could not even hear my language courses, an wen I put on some music"the music that comes with it" I had to cover my ears just to hear it! The next day after work, I whent back to the shop as, when I checked in a quiet place; at half volume no sound was even coming out of the clip+, The new clip started giving sound at about 1/3, but still when I got into a bus or in a windy street I could only listen to music at full volume, forget the language courses. Finaly now I will be able to use my Clip+ as I entended! Thank you! As for europeen regulation! If I ever meet the guy who made that law, he better have his runing shoes on, as I usually wear steel toed boots. For those who are wondering, my hearing is more tthan perfect, I will often hear thing other cant. And I use noise isolating earphones.
Thank you so much …it was driving us nuts
How are you able to get sound that is that loud?
I have the 8 GB Clip Plus, and I can barely hear it, even on HIGH. In fact, there is no detectable difference between NORMAL and HIGH at all. I have set it for all different regions, no difference in volume at all, and no way to boost it.
I used to have a Ipod Nano, and these same songs and ebooks were loud and clear through my car stereo without having to max the volume. Unfortunately, the ipod was stolen, so I opted for this cheaper product, and I cannot hear it in the car even with the car volume on MAX. Nor can I hear it with the earbuds crammed tightly in my ears.
I bought this so that I could listen to audiobooks while commuting 1 hour each way to work…and I also discovered it is not even loud enough to hear when I am exercising on my NordicTrack skier either… The room must be TOTALLY QUIET or I cannot hear my Sansa!
How can I fix this? I hate the idea of returning it… I want to listen to audiobooks in the car!
Hi.
OK I trued this and on my Sansa Clip+ and its made no difference whatsoever and its now all in Chinese so I can’t understand anything…
HELP Please
D
@markhamdarren wrote:
Hi.
It’s probably quicker and easier to just reinstall the firmware., than trying to navigate the menus in a forgien language. You’ll have to do that manually if you have the lastest version. The post will have a link to download it and instructions on how to do it.
After the clip+ updates itself, it’ll ask you to select a language and region.
How do I increase the volume on my zansa clip+?
The volume control rocker is on the side of the device. ![]()
Seriously though, this little guy puts out plenty of volume by itself. So much so that the EU determined it can be detrimental to your hearing, so they instituted a maximum level. But then, if you read the rest of this thread you already know that and the workaround in case you are affected by it.
The only other way to “pump it up” would be to use a headphone amp. Be careful though, hearing loss happens gradually over the course of several years, and you can never get it back. ![]()
Good thing I seen this thread, I didn’t know how powerful those headphones were that came with the clip were untill i tried them just now, blew my other ones out of the water! amazing sound quality! and with the higher level setting just makes this sansa clip experiece that more enjoyable. Thanks!
I have just purchased my sansa clip+ 8GB. It too has no volume control, and reseting factory default does nothing.
It has the newest drivers as default. Is there any way to get a hold of the old firmware and use this instead?
“When you re-set, you need to set the region to a non-EU region (such as N America or Rest of World).”
So simple… worked like a charm, thanks dude!
My new Clip+ does not produce enough volume to playback on my (also new) Logitech Pure Fi Plus speaker. It sounds fine in the ear buds and the volume control is set to High. Is this normal? I am using a cable to connect the Clip to the Speakers.
Tried a portable CD player with a different cable and volume is great. Went back to the Clip and volume is OK, but not as loud as with the CD player. I’m not trying to blow out the windows…but I do like to fill the room with sounds. There are no other adjustments on the speakers…just on/off and volume.
@miikerman wrote:
I’m not an audio guy here, but I wonder if the Clip just doesn’t have enough driving force to produce the volume you would like with the speakers , given their audio characteristics. If you wanted more volume, one thing you could do would be to get a small amplifier to use between the Clip and the speakers–while it sounds like a big deal, it really isn’t and there are some nice, inexpensive ones out there (such as by FiiO) that you could try.
I agree. These little mp3 players only put out “milliwatts” of power. They are only designed to drive ear-bud type phones stuck directly in your ear canal, not provide “room-filling” sound.
Adding a headphone amp would help, although a better way of doing it I think (with less hardware too) is to get AC-powered Computer Speakers. Some of them have sub-woofers as well, and are relatively inexpensive.
My experience exactly… It sometimes helps to be nerdy.
summerlove wrote:
It’s a legal thing.
Use the ‘reset factory settings’ option in system settings. For region choose something that isn’t Europe.
I had the same problem and found your solution. It works fine, thanks a lot.
These stupid Eurocrats! In order to save kids from their own thoghtlessness they prevent the older people from using modern technology and taking part in musical culture. I like classical music. This makes things more sophisticated as the volume level changes, and on “EU level” you can’t hear the quiet passages.
If the Eurocrats should ever forbid this workaround, I will have to file a suit at the European High Court for minority rights.
Thanks for the solution which worked perfectly. The Help Desk do know the answer but won’t tell you and refer you here. It’s a mad world.
You are simply a genius! I was so sad thinking of having to throw away ma little MP3 because I could not use it anymore in public transportations! Getting old and podcasting mostly cultural speeches, I badly need to have a normal volume.
Thanks for your help!
My Clip+ has a choice of High or Normal for the volume, though High still isn’t very loud with the earbuds that came with the device. Is the High setting the best I can do? I’ve cranked up the volume with the rocker switch already.
^^ Depends on your region setting i think.
