I just received my brand-new Clip 4.0 gb today with hopes of loading lots of audiobooks tonight.
Bottom line: My home PC (Windows XP, WMP 11.0.5721.5230) won’t recogniz the Clip but my work PC found it immediately upon connection.
At home when I plug the device into (multiple) USB ports on my PC, I repeatedly receive the “USB Device Not Recognized” message. I found the suggestions on the Sansa Support page and updated to the latest version of Windows Media Player – no luck.
I was able to charge the device enough to change manually to MSC mode – still no luck.
I tried running the Sansa Firmware Updater (current firmware = V01.01.18A) with no luck. The Updater doesn’t load and I’m guessing it doesn’t “see” the Clip.
When I connect the device, the PC says device unrecognized and the Clip says “connected” with arrows flowing between the picture of the Clip and the PC monitor. The battery isn’t charging, however.
Is there something magical I can try to get THIS PC to recognize the device?
I appreciate any suggestions you all may have!
Inga
