I’m trying to add my Sandisk M230 mp3 player to a new computer and when I plug it into the computer you get the ding as if it recognizes something was plugged in but the player doesn’t show up anywhere. So I put in the disk that came with the player when I first bought it and I get the following message…
Your operating systems requires an updated version of the Easy Start CD and then it gives me an option of accessing the Easy Start CD and Guide on the internet which takes me to a Windows site but I have no clue where to go from there or what to do.
Any ideas ?
The new computer I’m trying to add it to is the same exact setup as the old one so it shoud work. My operating system is XP if that helps.
