need a driver
helo everybody
im new here and need help
i have a problem with my c140 1gb mp3 player
it is not working anymore when i plug it to usb or
using d battery it only diplays the sandisk logo.
and the hardware wizard says unknown device
where can i download a driver for the usb device or
is there a software i can download to reformat it or restore its firmware.
i really need to make this work because its a gift from my only sister
and i really love it for that
thank u very much for ur time
What OS are you using?
dear friend i am facing the same problem. could tell me that how to solve this?
to help we will need more information about the OS you have. please provide as much information about the host PC as you can.
Dear friend,
 i am using Windows Xp. i am using the softwares available in the computer when i bought it. what i mean is i don’t  download much, i didn’t buy any software. but i think i have mediaplayer 10 or 11. is this will be sufficient to make  sansa C140 work? also please tell me that can i will be able to just drag and down the picts and see them on the C140 without any media convertor software?
thanks in advance.
can you still use the C100 mp3 player when its not connected to the pc?
If not, you may have to contact sandisk by email and ask for a fw
